Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Zanussi DWS939 D/Wash – Pump Impeller
- This topic has 12 replies, 6 voices, and was last updated 19 years ago by
MickGeorge.
March 13, 2007 at 6:46 pm #25812
MickGeorge
ParticipantHi Folks
Went to the above today and fished broken glass out of pump but impeller damaged and noisy when on wash ok.. on pump out..
Looks like an impeller kit available but looks like multiple parts in the kit and all the motor has to come out.
Question.. the impeller looks like it is held on by one screw so just wondered if poss to change without getting motor out also if motor has to come out how easy is it to get out? .. not had to get motor out on one of these before..
Thanks folks.. advice appreciated..
Mick
March 13, 2007 at 6:50 pm #207694clivejameson
ParticipantRe: Zanussi DWS939 D/Wash – Pump Impeller
Best answer is to pull the complete pump out…after you take off the lower rear cover, the pump is secured by a strap with two screws, it simply pulls out then. Just take your time over re-assembling the impellor kit onto the motor…it helps to note how the old one disassembles 😉
March 13, 2007 at 6:53 pm #207695bobokines
Takes two minutes to get the motor out.
Clear all water from the sump first.
Go to back of machine and take of lowr back panel (plastic bit)
You will find the motor bracket is held in by two screws retaining the motor.When the bracket is off the motor will just pop out.
Be a bit carefull when putting it back as you can twist the ‘o’ring. A bit of fairy helps.Bob
March 13, 2007 at 6:54 pm #207696bobokines
:waving:
March 13, 2007 at 9:26 pm #207697clivejameson
😆 :waving:
March 14, 2007 at 9:26 am #207698MickGeorge
Thanks for your advice folks… much appricated
Mick
March 17, 2007 at 11:04 am #207699cab
Hi from memory the kit has 3 different impellors count the number of blades and match with new one.
cab
March 17, 2007 at 6:32 pm #207700effzedarr
I also seem to remember if the sleeve on the motor shaft is knacked ,it’s a complete motor, might be wrong but something in the back of my mind says i might be right! 😕 😕
Chris..March 17, 2007 at 7:00 pm #207701Penguin45
You are right.
March 20, 2007 at 5:31 pm #207702MickGeorge
Been back today.. Stripped this and shaft that goes thru impellers and locks the whole asy together is cracked and not in kit..
Is this the shaft you guys on about and its a new motor job.. or is it just missing from kit? Seems crazy to me if a new motor required just for the sake of this part which I would have expected to be in the kit.. but that seems to be this job in a nutshell these days.. :rolls:
Comments appreciated
Mick
March 20, 2007 at 6:42 pm #207703clivejameson
That bit comes with a new motor 😥
….mind you, the reason why it splits is because the shaft has rusted underneath 😉
March 21, 2007 at 9:47 am #207704MickGeorge
Thanks Clive
Looks like a lost job then as I dont think she will pay for new motor.. but you never know..
The motor shaft wasn’t rusty but think the glass in the pump may have been the prob. Can’t belive they dont do thiis part as a spare tho..
Thanks for the help guys.. as motor easy to get out looks like strip down if I get this type of fault again.. presumably the wiring noise is the tell tail sound of the cracked shaft then?
Mick
March 21, 2007 at 4:47 pm #207705bobokines
I have used a pattern part from Connect (PMP9004) before now. It’s only about £30.00 trade.
Bob
