machine stopped full with hot water and soap, no lights but found rcd tripped.
unable to reset rcd with machine switch on and full of water.
manually emptied machine and then was able to reset rcd.
started rinse cycle and machine tripped rcd when water filled up to filter.
unable to reset rcd with water in machine.
emptied machine again reset rcd ok.
started normal cycle and machine tripped rcd again when filled to filter.
what is the cycle process
could it be circulation pump or element ?
any help greatly appriciated.
cheers
