Zanussi E33 fault
  • #36003
    keithos
    Hope some of you zanussi guys can help please
    Checked machine & found E33 fault . Incongruence between closure of anti boiling & first level contacts of pressure switch. Does this mean faulty anti boiling pressure switch? & is it small pressure switch near main one with 3 connections. Does not click when blown into should it?
    #249091
    Flyman
    Re: Zanussi E33 fault
    Small pressure switch is an electonic pressure sensor and will not click when you blow into it. An earth fault on the wash element can give you an E33 fault. (Don’t ask why cause I don’t know.) Also a blockage in the air chamber.
    #249092
    helo_75
    whether you needed the analogic switch before you blew up it or not, itll need replacing now, for sure
    just change em both and it will be fine
    #249093
    keithos
    Thanks for those tips. Changed both switches seems fine.
    keithos
