Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Zanussi Electrolux F/F – Fridge warm and strange clicking!!
- This topic has 4 replies, 3 voices, and was last updated 15 years, 2 months ago by
Stoods.
February 1, 2011 at 3:00 pm #60687
Stoods
ParticipantHi Forum Peeps,
My F/F is on the blink and before I rush out and buy a new one (Beko American Style GNEV220 – reviews appreciated!!) can anyone shed any light on the problem. So far I’ve checked the electrics at the back and all are fine. The light works, but the fridge is warm and there’s a clicking noise coming from the rear of the frideg, which is constant but not regular, if that makes sense?
Model No ZX564SI
Type B258886
PN 92588865301
S/N 32100095Thanks in advance
Stoods 😀
February 3, 2011 at 10:05 am #343249Seamy
ParticipantRe: Zanussi Electrolux F/F – Fridge warm and strange clickin
May be a faulty motor compressor, if it clicks off a few seconds after the motor trys to start.
February 3, 2011 at 10:15 am #343250Stoods
Thanks for the reply – if this is the fault is it worth fixing and why does the freezer still work??? Thanks again 🙂
February 4, 2011 at 8:11 pm #343251Seamy
Faulty compressors can start sometimes & sometimes click out on thermal overload if they have overheated. Its hard to know what the clicking is without hearing it & inspecting the appliance. Fan in freezer could be catching on ice either, if this was the case a total defrost & start up could cure the problem. Could be a noisy defrost timer clicking either.
Compressor change is a specialist job & not to cheap to be honest.February 17, 2011 at 7:53 pm #343252TheSpinDoctor
Hi.
The clicking is most likely the cut outs. The reason for your problem is most likely a failure of the defrost cycle. It could be a jammed defrost timer spindle or indeed a failed defrost heater assembly which on some does incorporate the aforementioned cut outs. The result of the failed defrost cycle is the air duct which carries cold air from freezer to fridge gets blocked by frost causing the fridge temp to rise.
