I have a problem with my dishwasher. No water is going in and it stops after a few minutes with ‘end’ light flashing twice which basically means there is no water coming in. All the manual suggests to do is make sure the water is turned on make sure the inlet is not blocked. I have done this and I have proved that the inlet valve is ok by taking it off and wiring it up to a 240v supply and turning it on with water connected and the water turns on/off as I switch the voltage on/off. I have measured the voltage to the valve when I turn the dishwasher and I am not getting 240v. I have belled out the brown wire to the supply coming in and this ok. The blue wire is obviously switched somewhere along the line but I need a wiring diagram from somewhere to try and figure this out.
Any advice, would be much appreciated.
Martin.
