Zanussi Dryer TE1120 91609762300
The toc has tripped several times I drill centre of toc to reset
I had to replace heater with new toc a couple of weeks ago
Still have trouble with Toc tripping,
I have checked condenser. Drain tube etc.
It is in a care home with different people using it so i cannot advise
Not to overload or stop machine,
It’s a expensive industrial machine but has the same heater as cheap models,
Any Zanussi engineers who see a lot of this problem
Can tell me what else to check.
Filter blocked or blockage in ducting , fan etc , not enough air passing over heater, so going out on over temp
Try washing filter in warm soapy water, sometimes a scum off overused conditioner in washing machines builds up on gauze of filter & not enough air gets through
You should be aware that safety devices are NOT TO BE TAMPERED WITH
they’re there to prevent it overheating & potentially being a fire hazard
