Zanussi error code 15-2?????
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi error code 15-2?????
  • #86423
    ZWF14069W-914904467/01
    Initial complaint, machine taking too long and a slight noise.
    No obvious noise problems, all functions, fill, tumble, heat, drain , spin appeared OK. Insulation checks fine.
    Diagnostics throws up 15 red-2 green?????
    Ran diagnostics several times and got this error code every time.
    Anyone have any idea what it may signify?
    bazza500
    Re: Zanussi error code 15-2?????
    Fault code is EF2. Overdosing with suds. Give it a good run through at high temp with nothing in it Jim and that should sort it, or strip the pressure system to clear.
    #431736
    Thanks Barry. 8)
