Zanussi essential 1600 6kg – drying cycle problem
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi essential 1600 6kg – drying cycle problem
  • #69438
    vcsggl
    Have a problem with the drying cycle on this 4 year old machine. Now tkes 2 – 3 times as long to dry a normal load. It heats, drum rotates but it isn’t really drying. When the door opens load is very steamy and quite hot. After a few minutes into the drying cycle there is a sound as though a motor is running at high speed but with no load on it – this sound was not present when the dryer was working properly. Where do I go next??
    George
    #374806
    captaincaveman1
    Re: Zanussi essential 1600 6kg – drying cycle problem
    Few things first you need to check the steam condensor at the back right corner what the fan sits on top of isnt blocked if its ok then you need to check the drying coil on the inlet valve isnt o/c and the noise is proberly the dryer fan assy worn .
    #374807
    vcsggl
    Many thanks – will do that and let you know the results!
    George
    #374808
    vcsggl
    condenser doesn’t seem to be blocked, fan is running smoothly, heating element comes on but clothes still not drying very well. What next??
    George
    #374809
    captaincaveman1
    check the condensor coil on the inlet valve isnt o/c
    #374810
    vcsggl
    Solved – thank you very much!
    George
    #374811
    ily0405
