zanussi f/f american style ..
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries zanussi f/f american style ..
  • #48923
    funkyboogy
    model zi8454x pd 925780657/03..
    4 door model , top section fridge is working ok
    bottom section frz dead,,
    twin compresor no power going to frz comp …
    check stats , defo timer they are ok ..
    on further testing i found there was no neutral feed to defrost timer , which i think also feeds compressor..
    does any one know anything about these f/f , and happen to know where the neutral feed that supplys defo timer comes from
    cheers ally
    #298186
    funkyboogy
    Re: zanussi f/f american style ..
    any one ???
    #298187
    Seamy
    think defrost timer is fed through thermal switches mounted on battery
    #298188
    funkyboogy
    sorry for sounding silly , but what/where is battery ??..
    ive got a wiring chart for f/f and it looks as though neutral just comes straight into both compressors .. but there a couple of items on wiring chart where neutral comes from that may be the cause of break ..
    wiring chart list the parts as a no ..ie 19 but i cant find any other doc that states what 19 is …very confusing
    ally
    #298189
    TheSpinDoctor
    The freezer evaporator.
    #298190
    funkyboogy
    the freezer evap ???
    #298191
    Seamy
    The type of evaporator in the freezer with the copper coils and aluminium fins is known as a battery evaporator.
    19 is listed as on/off switch (2 pole)
    Contacts 3-2 on defrost timer are closed during compressor /fan running, defrost timer should change over every 12 hours, contacts 3-4 bring on defrost heaters, thermal sw’ (27) switches off heaters at +10c, if this fails theres a safety thermal sw’ (26) operates at +40c. Defrost period should be approx 11mins.
    #298192
    funkyboogy
    cheers.
    this unit is built in and looks a bit of a nightmare to come out,
    so i have been messing around checking things from the front and below..
    ally..
    on the wiring chart i have it looks as though neutral comes straight from the mains in direct to the 2 compressors , but i guess it go somewhere b4 feeding freezer comp..
