zanussi f1203w auto
  • #64158
    senseib
    the programmer is skipping through on this machine on all programmes – is it the timer itself at fault?
    #356240
    Re: zanussi f1203w auto
    since nobody has replied to you
    if you want the service info let me have your email address
    Seamy
    Timer will skip on from where it was started, this is normal, it shouldn’t go all the way around to end though. If it does its likely that the p.c.b on timer is corrupted.
    #356242
    MickGeorge
    A loose tacho magnet will cause the timer to abort and skip to the end – worth a check?
    Although you may have tried this already
    Mick
