zanussi fault code
  • #66248
    QUICK FIX
    was at a zanussi sat and b4 anybodys says i forgot to take down the model in bit of a rush,the fault code is displayed at the end of the panel a vertical row of 8 lights the 1st 4th and 8th lights are flashing and i cant remember how you work the values out and my zanussi mates on his hols can anybody help 😳
    #363604
    Criscold
    Re: zanussi fault code
    E91 Communications error between main PCB and display board
    Check cable between boards + Check for insulation faults on heater/s + motor
    Colin
    #363605
    QUICK FIX
    thanks
