Zanussi Fault code EC2
  • #44620
    lyndy
    Zanussi fault code EC2 on ZWF1850W Pro 91400312000
    Appliance finishes programme ok then when you select new programme the code EC2 fault displays. To override you have to turn off appliance at wall then it will operate correctly on next prog chosen, when you reconnect power.
    #281656
    Re: Zanussi Fault code EC2
    Please do not post individual requests for help as a Sticky. If everyone did that the top of the forum would soon become clogged with stickies.
    If you don’t get an answer then by all means ‘bump’ your thread at any time. 🙂
    Thread unstuck.
    Specialist01269
    Hi: Can’t find this model listed on TDS but assuming that it’s a Dishwasher then the fault code EC2 relates to the output of the Turbidity sensor being out of specification, normally easy enough items to check & clean.
    HTH Andy.
    #281658
    Seamy
    Don’t see anything for EC2 listed
    EC1 is a flowmeter/valve problem.
    EC3 is a weight sensor problem
    #281659
    chris211
    the pnc is wrong 91400312000 is what it should be the fault code EC2 is turbiity sensor faulty= turbitity sensor faulty,wiring faulty,mainboard faulty would start at sensor
