Zanussi FC1100 nda
  • #66416
    pmb
    Hi i visited a Zanussi FC1100 wm (one of the small front loaders) with no drum action, i have traced the problem back to either the module or timer does anyone know which would be the problem? the motor and pressure system are fine and it doesn’t turn on the wash. Thanks for your help 🙂
    #364121
    Re: Zanussi FC1100 nda
    Have you done a visual check of module for burnt relay joint?
    Mike.
    #364122
    pmb
    Hi yes there is no visual damage to either the timer or module
    Thanks Peter
    #364123
    Worth checking the triac on the module. Looks to me like there’s no relay involved on that board. Was a heavy load washed in it last time or unbalanced load perhaps? I’m assuming you’ve got pnc 914010014/**
    What little gen is available is on Connect, maybe also on a TDS, not looked. Very rare for those modules to go wrong IME.
    Mike.
