Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Zanussi FF howling
- This topic has 10 replies, 5 voices, and was last updated 20 years, 2 months ago by
MD.
February 8, 2006 at 2:11 pm #15485
MD
ParticipantAs it says – I have a Zanussi fridge freezer and at irregular intervals it generates a howling noise. I have wondered if it could be a bearing wearing out or possibly gas/liquid being forced thru a small hole. Quite unnerving – been happening on an irregular basis for some time now.
Any thoughts chaps?
February 8, 2006 at 2:26 pm #163770Dave_Conway
ParticipantRe: Zanussi FF howling
MD wrote:Any thoughts chaps?
Yep, I thought “where’s the model number ?” So we know what we are advising on :martin:
February 8, 2006 at 2:27 pm #163771Simon46
Does it happen when you open then close the door?
Regards
SimonFebruary 8, 2006 at 2:46 pm #163772MD
Hi – I’ll add the model number later. It does it randomly at any time day or night. It was majorly creeping me out until I worked out where it was coming from. Its quite loud too and scares the cat… 😛
It doesnt make any difference door open or not. The noise lasts about 3-4 seconds each time, it can do it up to 4 or 5 times in a 30 min period then not for ages. I guess it will explode eventually and I’ll know what was wrong by the blackened bit….cheers Marc
February 8, 2006 at 2:52 pm #163773Dave_Conway
If it’s a frost free model it may well be the fan motor making the noise 🙂
February 8, 2006 at 9:43 pm #163774MD
Hi Dave
It is a Zanussi frost free fridge freezer – only model number I can see is ZFK56/52RF – it doesnt seem to mention what sort of coolant it uses.
Does this help?
What do you suggest to try to isolate the problem?Cheers Marc
February 8, 2006 at 11:29 pm #163775Dave_Conway
Apart from the fan motor I can’t think of much else that would make a noise that loud to be honest.
Perhaps it’s time to ask an engineer to attend and check it out ?
Try the repairs@ link below 🙂
February 9, 2006 at 7:19 am #163776farmboy
It sounds like refrigerant circulation noise, they are quite prone to it and theres no real cure. It can be worse when it’s just finished a defrost cycle.
February 9, 2006 at 9:12 am #163777admin
KeymasterRe: Zanussi FF howling
The howling can be caused by the delivery tube being too long and protruding too far into the evaporator. Especially on R600a systems this can cause strange noises as the gas boils off. I’ve tried regassing, without success I’m afraid. The delivery tube flexs under pressure and squirts the side of the internal wall of the evaportor, instead of a clean “boil” there is turbulance created, hence the noise.
So is the compressor running as this noise occurs?
There’s no cure, it’s an error at assembly of the evaporator which was probably not at the time of appliance assembly. If under guarantee contact your supplier.
Hope that helps
Kevin
February 9, 2006 at 9:23 am #163778Simon46
Does this model have the defrost drain tube with the end like a whoopee cushion above the compressor water tray? Have had one suck in air which made a groaning noise as it cooled.
Regards
SimonFebruary 10, 2006 at 9:08 am #163779MD
Thanks for your advice chaps. I’m not sure if I’ll do anything as it works perfectly apart from the noise.
cheers Marc
