Zanussi FJ 1296 washing machine
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi FJ 1296 washing machine
  • #6239
    p0xy
    I have a zanussi fj 1296 washing machine and when i turn it on i can hear the pump but nothing else. I have tried putting it on a wash and aspin but the drum doesnt move at all. Is it easy to change the motor and if it is how much does a one cost? I have had it about 6 years and this is the first thing that has gone wrong with it… please help 🙁
    thanks
    #116489
    Toni
    Re: Zanussi FJ 1296 washing machine
    I assume you have no motor action on wash or spin?
    Before you go changing the motor, I would suggest you check the carbon brushes on the motor, you may find they are worn away completely
    Toni
    #116490
    streetlighter
    Hi pOxy
    Watch the fill. If she starts to fill to far up the door you must get the w/m serviced as it may flood your floor.
    If fill is normal and no wash or spin, but pumps out ok then it could be carbons.
    If she washes and does not spin she needs a service.
    (Tricky on these so call an engineer in.)
    I asume you mean she fills and just sits idle ❓
    #116491
    p0xy
    Ye the washer fills and empties, but it doesnt go round at all spin or on a wash cycle
    #116492
    p0xy wrote:Ye the washer fills and empties, but it doesnt go round at all spin or on a wash cycle
    The problem will be as Toni has suggested and you need to check that out OR better still get an engineer in to do it 😉
    p0xy
    Ok will get an phone an engineer tomorrow thanks 🙂
    #116494
    Toni
    Look on the directories section, you may find a member that covers your post code area
    Regards
    Toni
