Zanussi FJ 1454W Board Fault ?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi FJ 1454W Board Fault ?
  • #26007
    Turbo
    This machine has no lights up on the control panel but the on light comes on ok but is dead otherwise.
    Changed the lead that connects the interface board to the main board but no better.
    No sign of any damage to either of these boards.
    Changed the main board and when I turned it on the 1st and 4th light on the right flashed on and off with a bleeping sound.
    I then noticed the wash pump had melted.
    Do you think I could have damaged the new board? 😥
    Thanks Turbo
    #208444
    Flyman
    Re: Zanussi FJ 1454W Board Fault ?
    Probably not 🙂 If the lights came on straight away and you are counting from the top downwards then you have E90 which probably means you need to configure the new board. Change the pump and try again. 🙂
    #208445
    Turbo
    Thanks for letting me know about the E90 error code. The problem I have now is I cannot access the diagnostic system to configure the new board by holding down the skip/reset & start/pause button and turning machine on etc.
    Turbo
