Zanussi FJ1033 bearings?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi FJ1033 bearings?
  • #5908
    I have a 10 year old Zanussi FJ1033. Spin has been very loud for many months, but now sounds like the machine is full of bricks! I assume the drum bearings have gone, but haven’t yet taken it apart (how to get the case off?)
    Q: is it going to be worth fixing, given it’s age, and how much is it likely to cost a) d-i-y or b) callout an engineer? If it’s over £100 my feeling is I’d be better getting a new machine..
    brian
    #114554
    If you are doing the work yourself you will be able complete it for under £100. Bearing in mind what you said – “Loud for many months”, – you will need the following components to make the repair – bearing and seal set, tub centre seal, and drum support.
    If you have the work done professionally, most engineers will charge for 2 hours work – it is a TOTAL demolition job! Establish hourly rate 1st.
    If you put up your postcode, a UKW engineer in your area may be able advise frurther.
    Re: Zanussi FJ1033 bearings?
    Thanks – I going off the d-i-y idea 🙁
    My postcode is CR3 5AH.
    brian
    #114556
    Try;
    Stellison Ltd
    14 Parsons Road
    Manor Trading Estate
    SOUTH BENFLEET
    Essex
    SS7 4PY
    01268 756276
