Zanussi FJ1033 Bearings
  • #6260
    Our zanussi is, after twelve years showing signs that it needs new bearings. I am a very practical person and have always serviced my own equipment. Is there a set of instructions available on the CORRECT way to disasseble and refit the new bearings ? before I do anything damaging..
    #116612
    Alex
    Re: Zanussi FJ1033 Bearings
    Afraid not. Such information may well contravene the consumer protection act.
    All I can suggest is ensure the plug is pulled out, take your time & follow your nose.
    Everything is done from the rear regards Tub/Drum removal, then you have to spilt the tub assembly and go from there. Make sure you replace the tub seal and ensure the drum spider is clean & unmarked.
    Best of luck, a nice Saturday morning job for you. Parts will cost about £60 assuming you need the drum spider.
    Alex
    #116613
    Thanks very much for the help Alex, I may leave it to the experts. Its a toss up between taking the machine to bits or a day on my narrowboat…..hard decision….not.
    Colin
