Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Zanussi FJ1033 overflow
- This topic has 16 replies, 7 voices, and was last updated 20 years, 11 months ago by
admin.
May 11, 2005 at 3:53 pm #9515
KeymasterHi,
I checked the posts and found one that describes my problem: water backs up through the powder dispenser a minute or two after filling and the drum starts to rotate. Sounds like the water level system has a block. The rubber boot between the drum and the dispenser is clear and intact. Question: just how much of an “expert” job is this to fix? Your Repairs@ link does not show a contact in my area (London W5)
Possibly due to the drum banging around? I’ve just replaced both lower suspension struts to fix this.Thanks for your advice in advance.
DavidMay 11, 2005 at 4:44 pm #134429Dave_Conway
ParticipantRe: Zanussi FJ1033 overflow
The drum banging around could be that it’s spinning when it should be tumbling at normal “wash speed” thus throwing the water back up the dispenser hose.
Does this sound likely ?
May 12, 2005 at 5:49 pm #134430DEG
Dave,
Thanks for your reply.
Now you mention it, it certainly could be spinning instead of tumbling as you suggest. Now that I’ve replaced the telescopic struts, what can I do about the drum speed? Is this a controller issue, perhaps?
David.
May 12, 2005 at 9:11 pm #134431Dave_Conway
Check the tacho magnet on the end of the motor, they fall off/come unscrewed 😉
Power off 1st please :plug:
May 12, 2005 at 11:54 pm #134432DEG
Dave,
I checked the end of the motor; nothing seems loose or missing. I checked the resistance across the of the tacho magnet leads and on my multimeter at 2000 ohms, the reading was 492.
Any comments?
Thanks,
David.
May 12, 2005 at 11:59 pm #134433Penguin45
David, the coil reading is acceptable; Dave’s concern would be the magnet in the middle being secure on the shaft. Also, check the motor for earth leakage – armature leaking to earth can over-ride the speed control circuitry and cause the motor to try and spin. If all OK, you’ll be looking at some sort of problem with the electronics.
Power off, of course…………..
Penguin45.May 13, 2005 at 7:59 am #134434DEG
Thanks Penguin45,
How do I check the security of the magnet? Is this beneath the coil, on the end of the drive shaft?
To check for armature earth leakage, do I check the reistance between each commutator segment and earth?
Thanks for your advice so far.
David.
May 13, 2005 at 8:11 am #134435Martin
DEG wrote:How do I check the security of the magnet?
Remove the retaining spring clip holding the tacho coil in place. The magnet is screwed into the end of the motor shaft, and being plastic often the threads getting stripped
DEG wrote:To check for armature earth leakage, do I check the reistance between each commutator segment and earth?
Yes :tup:
May 13, 2005 at 10:47 pm #134436DEG
Martin,
BINGO! As you predicted, the nylon thread on the tacho magnet has indeed been completely stripped. I TOLD my wife we wouldn’t have to get a whole new machine! (That’s the Scot in me)
I’ll certainly let you know if the machine fails to recover 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}.
Once again, you guys, thanks for your help.
Cheers,
David.
May 13, 2005 at 10:52 pm #134437kwatt
KeymasterRe: Zanussi FJ1033 overflow
DEG wrote:(That’s the Scot in me)
Oi, careful… there’s a small army of us here! :rotl:
May 13, 2005 at 11:03 pm #134438Dave_Conway
DEG wrote:Martin,
Who predicted ?? 🙄
May 13, 2005 at 11:16 pm #134439Penguin45
Sometimes we’re so damned sharp we’ll cut ourselves………
Penguin45 :rotl:
May 14, 2005 at 12:23 am #134440gegsy
OUCH !!!!
Why is Martin always right 😆Greg
May 14, 2005 at 12:34 am #134441Dave_Conway
Dave_Conway wrote:Check the tacho magnet on the end of the motor, they fall off/come unscrewed 😉
:lesson:
8)
May 14, 2005 at 7:14 am #134442Martin
Children! Children!…sit back down at your desks..P-L-E-A-S-E :lesson:
Now, the next part of the lesson is entitled: “Where can one buy a 50204873009 Tacho Repair Kit?” and the answer is (you’ll need to start writing at this point)…by emailing: spares@ukwhitegoods.co.uk
:rtm:
