Zanussi FJ1093 draining problem
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi FJ1093 draining problem
  • #13336
    snaggy
    I have a Zanussi FJ1093 and it’s been having draining problem. If I were to put the drain pipe down, water keeps flowing out and the machine just keeps filling water. If I lift it up (so water stops flowing out), come time to let the water out, the machine does not and it just stops there until I put the drain pipe down again and then it continues to do what it should.
    Can anyone here help me? I want to get an engineer but I thought it would be a good idea for me to understand what could have gone wrong. Any help would be very much appreciated.
    Thanks.
    #154268
    Re: Zanussi FJ1093 draining problem
    Almost certainly a pump motor failure – if it drains by gravity it won’t be blocked.
    http://www.ukwhitegoods.co.uk/modules.p … cts_id=394 is the one you want.
    If you have not yet sent for an engineer check in repairs@ or Directories for a UKW engineer in your area.
    Power off if you are going to investigate further.
    neptune
    It sounds like a faulty pump . Not easy to get at on a Zanussi . Most likely cause is a small object such as a match or a rubber band jamming the pump impeller . Unless you are qualified/experienced , call an engineer . If you are determined to attempt DIY , be sure to pull the mains electriciy plug out of the wall socket first
    #154270
    snaggy
    Thanks very much for your replies. I’ve already found an engineer from this forum but because the call-out charge is very dear, I thought I should at least understand what might be wrong.
    Once again, thank you very much!
