Zanussi FJ1093 – just sitting there
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi FJ1093 – just sitting there
  • #12823
    rmaddock
    My Zanussi FJ1093 has stopped playing ball.
    Turn it on, the power light lights but nothing else happens.
    I’ve checked all the inlet pipes and filters – okay.
    I’ve checked all the pressure switches – okay.
    I suspect the interlock but when I took it apart and powered it up it seemed to work. When I put it back in and selected a drain programme it seemed to work again. The interlock light came on and the pumps ran.
    I then put more of the machine back together again (i.e. the front panel) and tried again. Nothing. Back to being a Dodo.
    Is the interlock worth replacing or is the probem more likely to be elsewhere?
    Any guidance would be gratefully received.
    #151759
    Dave_Conway
    Re: Zanussi FJ1093 – just sitting there
    It’s nearly always the interlock that causes this fault but I obviously can’t be 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} on it.
    It’s here if you need one:
    Zanussi Interlock
    Or if you would like a definite diagnosis then an Engineer will be able to help 🙂
    Power off when carrying out any work please :zap:
