Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › zanussi fj1254w
- This topic has 7 replies, 5 voices, and was last updated 19 years ago by
suedehead1.
March 14, 2007 at 7:58 pm #25850
suedehead1
Participanti went to this machine today the pump was blocked when i cleared the blockage i cant get the machine to start. its the one with loads of lights but no display.
when i push in the on off button it lights up, then when i select the program the relevant lights come on but when i push the start button it beeps as if it is going to start but the light keeps flashing.
checked motor, pump, heater but cannot get it to do anything.
even the button to skip programs works but the machine wont start.any help gratefully received
March 14, 2007 at 9:03 pm #207859Bryan
ParticipantRe: zanussi fj1254w
It`ll have damaged the module , QER or EMW will repair and test it for around £30 +vat.
Bryan
March 15, 2007 at 1:05 am #207860aqualectric
Have you tried a new interlock? (You didn’t mention that in your list of suspects). 😉
HTH,
Steve.
March 15, 2007 at 8:30 am #207861eastlmark
ModeratorRe: zanussi fj1254w
Have you checked the pump is not open circuit? Or worse, short circuit and blown the module? Wouldnt think a blocked pump on its own would damage the module.
March 15, 2007 at 6:15 pm #207862suedehead1
i tried a new pump , the door lock is working there is no obvious damage to the circuit board. spoke to emw its not one that they do.
March 16, 2007 at 1:13 am #207863aqualectric
Just had a thought…. the user interface PCB (facia PCB board) on these type of machines quite often have communication problems due to loose or oxidised contacts on the board or its edge connector plug.
Remove the facia, unplug the edge connector, unscrew and gently prise the PCB out of its frame. Clean the contacts with emery paper and refit the PCB to the facia. Pinch the edge connector (plug) with pliers to tighten it and refit. Reinstall the facia and it should fire up! 😉Hope that helps!!!
Steve.
March 16, 2007 at 11:13 am #207864admin
KeymasterAllways run (enter) in service program for get more info about your problem… beside to check and get stuck on anything else.
Not all errors are displayed on user mode and in consequence simply is not starting.March 16, 2007 at 8:17 pm #207865suedehead1
thanks for eveyones help i really appreciate it cleaned up all contacts its working ok what a surprise the edge conectors were oxidised. the machine is in a damp enviroment.
