Zanussi FJ1254W Washing machine- Error code
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi FJ1254W Washing machine- Error code
  • #74730
    Latham63
    Ok machine stops in cycle with Start/pause flashing + 3rd/4th led`s also lit.Pump found to be worn out & has been replaced.Still comes up with this error code? Anyone know?
    #392674
    Re: Zanussi FJ1254W Washing machine- Error code
    The vertical LED’s on the far right you mean?
    #392675
    Latham63
    Yes
    #392676
    Well as a rule LED’s 3& 4 would be accompanied by at least one other from the remaining 4 LED’s below. The first 4 represent the first error code the last 4 the second. So from what you have it reads error code E3? ( analogue pressure switch based error)
    #392677
    Latham63
    Problem turned out to be very low water pressure.The water softener fitted to house supply was blocked! Bypassed ok.
