Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › zanussi fjdr 1666w
- This topic has 17 replies, 5 voices, and was last updated 17 years, 8 months ago by
bluejack.
August 2, 2008 at 3:50 pm #38483
bluejack
Participanthi, this machine was filling then a minute later it was emptying , no fault displayed , so i replaced the recirculation pump still the same thing happens i checked the pump and there is no power to the to the pump . ive checked the board but there are no marks on it , any ideas thanks.
August 2, 2008 at 5:35 pm #259052leavemetogetonwithit
ParticipantRe: zanussi fjdr 1666w
Damp motor (condensation on plastic brush holders) can throw up odd faults.
Mike.August 2, 2008 at 10:02 pm #259053roly16
If you mean it filled up and then emptied straight away without tumbling or circulating, the drain hose could be too low down so that it’s syphoning out when the water level gets to the same height as the top of the drain hose
G
August 3, 2008 at 5:25 am #259054Flyman
You say no fault displayed but did you go into the diagnostic system? It will only show certain faults to the customer, the rest you have to be in the diagnostic system to see them.
August 3, 2008 at 5:53 am #259055bluejack
it fills with a little water turns for a bout a minute then starts to add more water, but then emptys and the display shows 3 is this time remaining or a fault, is not the wast pipe thats at the right hight , how do i go in to fault mode?
August 3, 2008 at 6:52 am #259056BobHope
Hi bluejack,
pm me your email address and i will send you some info.
Bob.
August 3, 2008 at 9:12 am #259057roly16
What on earth are you guys all doing up at 5 am on a Sunday morning?
😯August 3, 2008 at 1:44 pm #259058Flyman
Sad b*ggers with no life.
No , just sad b*ggers with the time on the forum set wrong. It was actually 6am.
😕August 3, 2008 at 4:08 pm #259059roly16
I rest my case
August 3, 2008 at 6:11 pm #259060BobHope
hi bluejack
email sent hope it helps.
as for roly16 and flyman it was posted at 7.15 am and when you lot have grandkids you will understand, its always a 6 am start in this household
when they stay :lol:.hope you are keeping well G.
Bob.
August 4, 2008 at 10:30 pm #259061roly16
Didn’t think you were old enough to have grandchildren Bob 😯
It must be the job that keeps you looking so young.
But yes thanks; I’m keeping well; hope you are too.
Geoff
August 5, 2008 at 7:03 am #259062bluejack
hi, many thanks for that bob, good information it shows E85 the circulation pump so ive ordered a new one and ill let you know if it works , my daughters 4 month old gets me up at 5 for a feed .
August 5, 2008 at 2:52 pm #259063leavemetogetonwithit
Odd. In post one you said you had replaced the “recirculation pump”. So what is the “circulation pump”?
mike.August 5, 2008 at 4:15 pm #259064bluejack
hi, replaced the recirculation pump with a spare and then with a new one but it still is showing E85 ,and cant be reset in the diagnostic mode, so i think its the board unless anyone has any other ideas, thanks.
August 5, 2008 at 9:52 pm #259065leavemetogetonwithit
OK well the only other thing left is the wires/connections from the board to the pump since you have no power to pump.
However, I see there are two totally different boards listed on connect for that model. Does it have two boards?
Mike. -
