zanussi fjdr1466w intermitent fill
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries zanussi fjdr1466w intermitent fill
  • #68652
    JENKS
    above machine starts as normal but will only fill every now and then.once filled will go thru cycle as normal.first thought was sticking inlet valve so replaced but still same fault.no error codes shown,any ideas appreciated
    #372150
    Re: zanussi fjdr1466w intermitent fill
    Clean out the air chamber, sump hose and the top vent hose as one or all 3 are clogged. 😉
    #372151
    JENKS
    sump hose,pressure chamber and all pipes clean,all i get is pump runs for approx 10 seconds then nothing after pump has stopped
    #372152
    Slight change of story from what you said earlier ….Fills then stops is symptomatic of brushes or even a duff heater?
