PNC 914516806-00
Complaint of no drain. Machine was full of water on visit, drained perfectly into a bowl so no blockage. Pump has no obstructions and appears physically and electrically sound. Customer did say that they tried it once without a load and it worked but failed with washing in. 😕
Also thinks she saw E20 once.
Switched on, selected drain and pump ran fine and drained out the last few drops of water.
Selected Cottons- Rinse cycle. filled, timer counted down to 41 Mins then stuck.
Switching to spin or drain and pump will not now run.
Unfortunately I didn’t have my lappy with me, it was at home charging up a brand new battery, so I will have to return to run diagnostics, just wonder if anyone has any previous on this fault. Could it be a board triac fault or the pump TOC?
