Unable to follow this up as cust decided to buy new machine but thought you wizz kids out there might offer some advice should I come across this fault again.
Fault was that water valve and pump activated at same time and could not select programe. window showed three bars as it does before programe selected but could not select programe just kept pumping and filling at same time.
Could not even select diagnostic mode so thought this was module fault.
Got new module and fitted.. machine just beeped at me and could not select dignostic mode to configure board. Double checked connections and rechacked against my wiring diagram made before disconecting original board but ok.. refit orig board went back to pump and fill mode as before.
Any idea’s?
