Zanussi FJR1254W Error Code E90
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi FJR1254W Error Code E90
  • #22418
    biggoolie
    Can anyone tell me what this error code signifies, I’m going to the machine tomorrow but the fault code is’nt listed on those already posted. Thanks a bunch.
    #194863
    Re: Zanussi FJR1254W Error Code E90
    Comms error. Wiggling the ribbon cables between the boards usually sorts it… Most of the time…
    AMS
    E90 is the user code. You’ll need to go into the diagnostics mode to see what the specific code is. It could be anything from E91 to E94. In my experience, these codes usually end up with a pcb change.
    cab
    front user board has allways been a problem on these machines from conception, E91 comunications error between userpcb and main pcb, very rairly main pcb.
    cab
    #194866
    scots
    I have the same prob E90. its intermettent, when I tried, it started within a second or so.
    Reset and worked ok, functionally tested and ok… WEIRD!!!
    Anyone else got any ideas?
    #194867
    scots wrote:Anyone else got any ideas?
    I second the comments of the previous postee’s. Wiggle your ribbon cables or better still take both ends off and pinch the blocks before refitting…sorted! 😉
    #194868
    scots
    Worth a go, will try next week and post the result.
    #194869
    biggoolie
    Thanks for the replies, seems like this is quite a common fault, going back tomorrow so will try these ribbon cable connections, thanks again.
    #194870
    bobokines
    I bet you will find coffee stains down the front of the machine!
    Bob
    #194871
    Most of intermittent E9_ cases in me were dirty PCB around ULN2003 (SMD) in user interface electronic. If don’t work at all and shows only E9_ was ULN it self (changing remove problem).
