Machine has gone crazy! Original fault was timer sticking and no spin.Checked motor brushes ok,tacho in place etc – suspected the timer so fitted one from EMW,the machine now spins but only for thirty seconds and then switches back to tumbling action then spins again for thirty seconds etc until it switces off.On filling on C wash the machine goes into a fast tumble and the circulation pump comes on and off as the pressure switch clicks away. Ive cleared both pressure tube hoses.Whats going on?Why two pressure switches with a myriad of wires attached.Ive repaired plenty of these before but mainly motor/timer/bearing faults.
