zanussi fjs1225
  • #10427
    have got a zanussi fjs1225s with a strange fault
    tha machine goes through the programme to the end without stopping but the machine does not heat
    have changed the thermistor on this to no avail
    have managed to come across a new pcb for it but this does nothing and i believe you need it programming by service force (at a high fee ) or is their a way round this
    am i missing something or is it wait for a good s/h board
    #139887
    Dave_Conway
    Re: zanussi fjs1225
    You need to configure the PCB to “tell it” which machine it’s in.
    If you post the PNC I’ll send the relevant details to you 😀
    #139888
    FLORIN
    Re: zanussi fjs1225
    Hi there,
    It happened also to me Dave, and I tryed to change the transistors witch are implicated in the circuit of that relay who give the electric power to the heater thru the pressure switch`s contacts…
    But no result. 🙁
    Cheers,
    Florin
    #139889
    Re: zanussi fjs1225
    @ dave conway
    prod no is 914512801 / 00
    @ florin
    did not think it was a relay driver fault because the programme went through as normal. if it had been i would expect some sort of fault code. did your machine stop or not. sometimes i would play with the board and it would start to heat but then it would forget to stop and boil everything. I have come to the conclusion that the temp measuring circuit must be faulty and tells processor that it is already up to heat but that does not tell me why when i get it to heat it boils
    sent board to tony at emw in the hope theycould fix and they put a new relay in desperation and hope but it did not work
    FLORIN
    Re: zanussi fjs1225
    Thanks Dave,
    I will do so.
    Cheers
    Florin
    #139891
    Dave_Conway
    Re: zanussi fjs1225
    electrofix wrote:prod no is 914512801 / 00
    Will be with you in the morning 😀
    I still can’t get TDS to work on this machine at home :haier:
    #139892
    FLORIN
    Re: zanussi fjs1225
    IT`S ALLRIGHT DAVE ,I`LL BE WAITING.
    FLORIN 🙂
    #139893
    Re: zanussi fjs1225
    thanks dave will order the disk sounds good value will check again am when at work
    Dave_Conway
    Re: zanussi fjs1225
    Email on the way 😀
    #139895
    Re: zanussi fjs1225
    thanks dave got file
    will keep you posted
    Re: zanussi fjs1225
    put machine code in new board now working a treat
    have had this machine for 18 months i knew the answer would come one day
    original pcb was faulty not allowing machine to heat
    according to manual this machine skips heat section if taking too long so we could have a lot of machines out there were the customer does not know there is a fault
    Thanks Dave 😀 😀
    #139897
    Dave_Conway
    Re: zanussi fjs1225
    No probs Dave, glad it worked :tup:
    #139898
    Mark1
    Just a quick note, I have all tech data and various codes for Zanussi jet sytem type electronic machines
    #139899
    Dave_Conway
    Re: zanussi fjs1225
    Thanks Mark 😀
    Welcome to the site by the way.
