Used the diagnostics on this machine, then reset it for the customer to use. She now says that there is no beep from the PCB…….anyone know how to switch the beep back on? :conf:
I’ve never had this problem before; didn’t know you could affect the buzzer with diagnostics. TDS gives no clues……..anyone know??
DeActivate + Activate OF THE BUZZER AT THE END OF THE PROGRAMME
By pressing the “TEMPERATURE” and “SPIN” buttons at
the same time (or the temperature button with button 4) it is
possible to disactivate the buzzer sound which indicates the
end of the programme; by repeating this operation the
buzzer will be activated again.
This function is always available and is memorized until it is
modified.
