zanussi fjs1225 stuck on pause? Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › zanussi fjs1225 stuck on pause? This topic has 6 replies, 4 voices, and was last updated 18 years, 5 months ago by phil59. Viewing 7 posts - 1 through 7 (of 7 total) Author Posts November 10, 2007 at 3:27 pm #32093 phil59Participant hi guys been out to this mc zanussi fjs1225 door locked if you try a prog the start light just flashes as if its stuck on pause ive tried unpluging from the mains and the door unlocks but as soon as you plug back in it locks again and wont run November 11, 2007 at 3:35 pm #233588 adminKeymaster Did you managed to get in service mode? Door is locking on as soon as you turn machine “on” in case of first water level is activated. But machine should work forward… Try to get into service and see which error is revield… November 11, 2007 at 4:17 pm #233589 phil59Participant Re: zanussi fjs1225 stuck on pause? hi barron how do you get in service? cheers in advance phil November 11, 2007 at 4:32 pm #233590 Penguin45Participant Re: zanussi fjs1225 stuck on pause? Big file in your inbox, Brian. Chris. November 11, 2007 at 4:52 pm #233591 phil59Participant Re: zanussi fjs1225 stuck on pause? cheers guys thats brill phil November 11, 2007 at 6:34 pm #233592 SimonCDParticipant Re: zanussi fjs1225 stuck on pause? you will probably find motor down to earth, had a few do that November 11, 2007 at 8:51 pm #233593 phil59Participant Re: zanussi fjs1225 stuck on pause? cheers simon ill check it out Author Posts Viewing 7 posts - 1 through 7 (of 7 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
