Zanussi FJS1225W a/w
  • #46025
    E34 anyone? Machine demostrates generally bonkers behaviour with random stopping and starting (pause/start will set it off for a short period of time), so pretty sure there is a pcb problem. Most E3-‘s seem to point at the water level control circuitry. Nothing on E34 though.
    All ideas welcome.
    Re: Zanussi FJS1225W a/w
    Penguin45 wrote:All ideas welcome.
    Colour Catcher stuck in sump hose causing pressure switch to click on and off in perfect rhythm with the wash pump….in, out, in, out, slush it all about…..???? 💡
    #287973
    geoff1
    Have sent copy of manual
    Geoff
    #287974
    aqualectric
    There is an E34 code Chris….I quote verbatum…… 😉
    E34 – Incongruency between level of electronic pressure switch and level of anti – boiling pressure switch 2 (duration of fault at least 60 seconds).
    Cycle blocked; door closed.
    Possible causes:- Hydraulic circuit of pressure switches; electronic pressure switch, pressure switch; wiring; main PCB.
    Above quote from TDS.
    HTH,
    Steve.
