Hi,i have a zanussi fjs1397w it required motor brushes which ive done.but now when i select a programme it just clicks onto next one and keeps going it doesnt sit on any programmes it only stops when its at the end of programmer.Any idea’s?Can the programmer be faulty?cheers
Re: zanussi fjs1397w running through cycles non stop
Yeh checked the motor.it was fine it did 2 full washes after brushes changed then i had to replace the waste pipe after i changed waste pipe it went downhill from there.you put it to cycle A say and it will every second change to next cycle it will continue doing this till the dial stops at end of the programmes.
Yeh i checked that aswell as i was at that end of machine.I’m puzzled as i said it done 2 full washes and as it was leaking with a burst waste pipe i decided to change waste pipe.after the change the machine just cycles through every segment on dial no drum movement no filling it just tries to drain.
