Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Zanussi FL – 1081 washing machine problems
- This topic has 6 replies, 3 voices, and was last updated 16 years, 10 months ago by
sean68charger.
June 5, 2009 at 2:34 pm #46228
sean68charger
ParticipantI have owned a Zanussi FL-1081 for 12 years and has given excelent service up until christmas last year when it started to “stick mid program and I then had to move the dial by hand to finish the cycle.
The timer gets stuck on some but not all programes,
I have replaced the timer and door switch (£110), cleaned and checked the pressure vessel and it worked fine up until now. I stripped and cleaned the pressure vessel again yesterday, checked all parts but it still fails to operate properly.
I am reluctant to buy a new machine as everything on the fl-1081 seems in great order apart from this problem. I have also checked the two diaphragm switches at the top and they suck/blow without leakage.
I am wondering if it is another faulty door switch. or has anyone got any advise?Please help!!
or do I cut my losses and buy a new one after 12yrs? -whats the new equivalent?
I would love to get another year out of it,
Cheers
Sean
June 5, 2009 at 2:38 pm #288625bazza500
ParticipantRe: Zanussi FL – 1081 washing machine problems
Where does it stick?
Does it stick full of water or empty?
When you click it on does it complete the cycle then on its own?
June 5, 2009 at 2:43 pm #288626sean68charger
bazza500 wrote:Where does it stick?
It sticks in various postions, not all the same, if you click it on it will go for a while then need doing again or sometimes complete the cycle.
at the moment it sticks mainly on the start of the delicates/synthetics/coloured programe.
It does fill with water, and heat it too. it has even stuck on spin and the drain settings.
June 5, 2009 at 2:56 pm #288627bazza500
Sticking at the start of the programs could point towards an inlet valve problem however this would not explain the sticking on spin and drain which sounds like a pressure system problem which you say you have cleaned, or a faulty pump.
June 5, 2009 at 3:09 pm #288628sean68charger
could it be the two diaphragm pressure switches?
June 6, 2009 at 12:04 pm #288629philfish
iirc correctly the the drain pump and the valves are on the same circuit so if pump goes down it wont fill so it could still be a valve problem. i would also be looking at the pressure chamber they have a nasty habit of getting blocked or partially blocked causing some strange problems just something to check for.
phil
June 6, 2009 at 9:59 pm #288630sean68charger
philfish wrote:iirc correctly the the drain pump and the valves are on the same circuit so if pump goes down it wont fill so it could still be a valve problem. i would also be looking at the pressure chamber they have a nasty habit of getting blocked or partially blocked causing some strange problems just something to check for.
phil
She does fill with water and drain if you move the dail manually, it tends to stick mostly at the very start of a cycle and at the end of the cycle. I have had the pressure vessell out and cleaned it again, (clean anyway, is this what you call the pressure chamber?)
washing is building up now and missus is naggaging for a new one!!!
Sean -
