Zanussi FL-1084
Viewing 15 posts - 1 through 15 (of 22 total)
  • #68295
    Muv
    Got one of these that wont do the spin cycle
    Is it likely to be the brushes, or the speed module …
    Can’t find brushes anywhere.. But found module at over £100!
    Muv
    #370485
    jeremy
    Re: Zanussi FL-1084
    does it have an induction or commutator motor?
    do you have any drum rotation at all ?
    does it distribute just not ramp up ?
    #370486
    Muv
    Zanussi FL-1084
    Has the commutatir motor, distributes fine, just no high speed spin
    #370487
    Re: Zanussi FL-1084
    Common fault on the old machines with hybrid timers, if that’s what it is. EMW time.
    Mike.
    #370488
    Alex
    Re: Zanussi FL-1084
    80{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} Chance brushes, if never been replaced before make it 95{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}
    They are not shown on any exploded pictures, but anyone in the trade would recognise which ones as soon as they see the old ones.
    Alex
    #370489
    Muv
    Zanussi FL-1084
    Ok thanks for all answers, I’ll take brushes out first and match them up…
    Watch this space!
    Muv
    Zanussi FL-1084
    Well, finally changed the brushes, which weren’t that bad, but decided to try them anyway
    Still same fault … Timer next I spose….
    #370491
    Re: Zanussi FL-1084
    Check with EMW. http://www.emwelec.co.uk. They will send a re-con timer which you can return if it doesn’t do the trick. I think that one has a separate module which they will also probably stock, so ask them which it’s likely to be!
    Mike
    #370492
    Muv
    Zanussi FL-1084
    Is this timer easy to fit.. Looks like a load of cogs in front of the timer shaft!
    Muv
    #370493
    Re: Zanussi FL-1084
    Piece of cake. The cog(s) are keyed – only one way they can go.
    Mike.
    #370494
    phooey69
    Re: Zanussi FL-1084
    I had one like that it turned out to be blocked air chamber on the manifold, as the motor control goes through the pressure switch, cleared the pressure hose and the machine would then go into full spin
    #370495
    Muv
    Zanussi FL-1084
    I’ll give that a try as well
    #370496
    Re: Zanussi FL-1084
    BTW, After checking the pressure switch (only need disconnect the p/hose to check that) if you haven’t looked at the module yet, you should go there next. You might find a dodgy, partly burnt solder joint on a relay terminal or just possibly a swollen or leaking capacitor.
    Mike.
    #370497
    Muv
    Zanussi FL-1084
    How do you get the speed module out of its holder … It’s seems stuck solid!
    Re: Zanussi FL-1084
    Muv wrote:How do you get the speed module out of its holder … It’s seems stuck solid!
    Just simply unclips and slides out as a rule, unless some miscreant has had it out before and forced it in without sliding it down in the holder channels that is. Either way it should come out without too much force required.
    By the way, have you got around to checking the air bell and made sure the pressure hose ain’t bunged up?
