Re: Zanussi fl1012
Martin wrote:
snoody wrote:
Can anyone help?
Remove outer timer knob (force is best – pair of pliers) Undo the 7mm nut holding the inner knob in position. Remove knob and spring, then unclip indicator dial away from timer cam and pull free.
Lid off, remove philips screw holding timer in position, unhook bracket from fascia and turn towards you to access timer bracket and remove the 2 screws holding it in place. Ease bracket clear of timer enough to remove the cam.
Replace Cam (50654768006) Inner Knob (50099627007) and Outer Knob (50099625001)
Reassemble in reverse order……… 😀
Easy!
Thanks for the info shall order bits and give it a go
Again many thanks
Steve 😀
