zanussi fl1081 bearing
Home Forums Public Support Forums Spare Parts Help zanussi fl1081 bearing
  • #17143
    craigybell
    The drum bearing for my zanussi fl1081 washer needs replacing again. I replaced it in November but it sounds as if its gone again.machine also leaking water.Is it time to give up and scrap the old girl?? If so any recommendations around the £300 mark
    type p6596303 prod no. 91478915/00
    #173132
    Re: zanussi fl1081 bearing
    craigybell wrote:Decided to repair machine and have dismantled it.Looks as if I need a new spider as well since its heavily scored where the inner bearing is seated and also where the outer bearing has contacted it.Probably was scored the previous time the bearings went and I should have changed it then bah!
    Drum support is in shop@ here:
    http://www.ukwhitegoods.co.uk/modules.p … cts_id=144
    as are the bearing kit and tub seal.
    Better luck this time,
