zanussi fl1084al Timer wont progress
Home Forums Public Support Forums Help And Support Washing Machine Help Forum zanussi fl1084al Timer wont progress
  • #51691
    smiffy2044
    Many thanks for opening this, ..it is appresiated
    Zanussi FL1084AL – 914780142 – The timer wont progress at the start of the program – for example from C or H. Seems to work fine towards the end of programs and is progressing normally.
    On H the tub fills, water switches off at level (about 1/3 up window), it starts to adgatate washing but never moves to D.
    Same happens on other programs
    Checked and tested in operation on other parts of program.
    Motor – OK
    Heater – OK, water getting hot in other parts of programs
    Door switch OK and light working
    Water valve (only using cold) – OK
    Pump – Checked and cleaned – OK
    Not checked – 2 switches mounted on side of drum
    The larger pressure switch is stopping the fill using the pipe from the sump, not sure if this is correct ? Also havnt tested and not sure what the smaller pressure switch does.
    Any ideas please or info on untested items and how to check.
    Its a good machine still so would like to save it from the scrapheap. Many thanks..it is appresiated
    #308969
    aqualectric
    Re: zanussi fl1084al Timer wont progress
    Possibly a blocked pressure system – follow the small hoses down from the round pressure switches to the top of the filter / pump housing. This is the “pressure chamber” and it is probably full of gunge. The unit will need to be removed from the machine to clean it thoroughly. One pressure switch controls the water level and the other is for heater protection. The water level on the main washes is rather high at 1/3 up the door glass: only the rinses should be this high. So I would suspect the pressure system as a first point to check.
    Power off before any inspection starts. :plug:
    Hope that helps,
    Steve.
    #308970
    smiffy2044
    Great thanks, i’ll try that later an post accordingly.
    #308971
    smiffy2044
    Yep, that sorted it. The unit was clogged up. Upon cleaning the water level is only 10{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} up glass and it runs perfectly. Cheers
