zanussi fl1085
  • #10712
    help I have a fl1085, when in wash mode it seems to spin and send out a lot of water from the powder drawer can anyone help
    #141596
    Pat-UK
    Re: zanussi fl1085
    First thing First PULL OUT THE MAINS PLUG.
    Then if you can lean the machine back a little (get someone to hold it if poss) and have a look underneath at the motor, There should be a small magnet fixed firmly to the center of the spindle by a plastic screw.
    These often become loose and either fall off or come to far out to work properly, You should be able to screw it back into place and that should sort out your problem,
    While your there, make sure the Tacho coil is pushed firmly back in place with the little spring clip thingy in place.
    If the thread is damaged on the magnet (will not do back up and just keeps turnng round) a repair kit is available from Dave click on the spares section and send a message from there
    Hope this helps
    Pat
    #141597
    Re: zanussi fl1085
    Pat your an absolute star, done what you said and it works a treat now.
    Many thanks you’ve saved me £350, we nearly brought a new one last night.
    Cheers
    Wayne
    #141598
    Pat-UK
    Re: zanussi fl1085
    No problem.
    That’s what we’re all here for.
    Glad it all worked out OK.
