Zanussi FL1085 washing machine not heating up
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi FL1085 washing machine not heating up
  • #49159
    geraldferreira
    Zanussi FL 1085 stopped heating up. Took the back off checked the element and although it measured 22ohms but it showed some leakage to earth, so ordered element from UKW and replaced, but no change, still does not heat up. I checked the thermostat and it measured open circuit, which I presume is correct when cold. Other than not heating up the machine performs all the correct cycles. Is there something I am missing.
    Please advise.
    Gerald Ferreira
    #298915
    TheSpinDoctor
    Re: Zanussi FL1085 washing machine not heating up
    Hi.
    There should be some resistance across the NTC sensor. If not, that could very well be the problem although I would also suggest you check the air chamber.
    #298916
    geraldferreira
    TheSpinDoctor wrote:Hi.
    Thank you, is the NTC sensor the thermostat? if so it is definately O/C, I shorted out the leads to it with no change to the element heating up. Both air chambers seems to operate when the water lever rises. I also blew into them and certanly the contacts switched over. But now I think I have really broken it, I decided to pull out all the connectors on the circuit board to clean them, put them back and now no matter what programm you put it on it cycles right through at great speed, not waiting to finish one thing before proceeding onto the next. WHAT HAVE I DONE????
    #298917
    TheSpinDoctor
    Well, it soungs like you may have a timer fault there. If so, this could now be getting a little pricey. Either that or you have wired it up wrong somehow.
    #298918
    geraldferreira
    TheSpinDoctor wrote:Well, it soungs like you may have a timer fault there. If so, this could now be getting a little pricey. Either that or you have wired it up wrong somehow.
    I have rechecked the connections and I am sure its is connected correctly, maybe I just aggravated the fault on the timer board. I looked up for a replacement on the UKW parts but I didn’t see one available. Would you know where I can get one from.
    Many thanks
