Zanussi FL881 belt.
  • #44126
    aqualectric
    Zanussi FL881 washer. PNC 914789090. Serial no: 62401166.
    This machine uses the induction motor with the centrifugal collapsible motor pulley. The belt is a vee belt EL4 XL512. TDS shows 1240206001 as the correct belt.
    The new belt is about 3 inches shorter than the original!! The numbers on the belt match exactly but it will not fit without forcing it on. The pulley cannot operate to increase the spin speed as it is far too tight and there is no adjustment on the motor at all.
    I have checked and double checked; I just can’t seem to find the answer. The old belt works perfectly but is splitting so needs to be replaced soon.
    Any ideas? 😕
    Thanks,
    Steve.
    #279865
    Re: Zanussi FL881 belt.
    bit of a long shot but have had wrong numbers printed on belts before
    looked through workshop manual quickly not a lot of info on this system but works the same as the ariston autos used to with variator pulley. some of these belts seemed bigger when put on due to wear in the width but nowhere near 3 inches i would look at wrong belt
    have you got a v belt supplier in your area we have one called fpt used to be called fenner belts
    http://www.fptgroup.com/
    find local branch and take old belt to them see what they can do
    hope this helps
    aqualectric
    Thanks for that, Electrofix!
    There’s a depot in Poole that I pass each day….never even knew it was there!!
    I really appreciate the information – hope they have it in stock tomorrow! 😀
    Cheers,
    Steve.
    #279867
    spanner51
    Connect list an pattern belt for this model as size 4L520, but sadly NLA (5031680192797)
