The machine (Zanussi FL884) has an intermittent fault. When using a rinse hold program, the programmer has to be turned to position “F” to empty and spin the load. However, instead of doing that, sometimes it simply tumbles slowly for about 10 mins, and advances to program end with the water still in the machine, and no spin. I have also seen a program without rinse hold, do exactly the same, leaving the machine full of water, and no spin. To overcome the problem, I turn the program control around to position F, and re-start until I hear the usual emptying sounds, and the machine will then spin and complte successfully. The programmer was replaced about 4-5 years ago, the capacitor about 3 years ago, and the door interlock about 2. Any advice on where to look for the fault would be much appreciated.
