Zanussi FLA1201W
  • #10693
    Twoten
    I have just looked at the above machine prod number 914789706/01. The belt has come off the pulley and taken the wireing loom from the thermistor with it. Can anyone advise on a part number for the loom that runs from the thermistor on this machine? If this is not available has anyone got a wiring diagram and part number for the rasta plug that fits on the thermistor.
    Thanks,
    Keith.
    #141515
    Dave_Conway
    Re: Zanussi FLA1201W
    There are harnesses available on the parts list but it doesn’t indicate which one is which 🙁
    The thermistor though only has two standard terminals, can’t the plug be cut of and two spades crimped on ? It doesn’t matter which way round they go on a thermistor.
    #141516
    Dave_Conway
    Sorry, forgot…..
    Wiring diagram on the way via email 😀
    #141517
    Twoten
    If only life was so simple 🙂
    Although the thermistor only has 2 terminals there are 3 wires (all orange) and they go into a 3 way Rasta plug.
    Once i have the wireing diagram I can work out what should be connected and use insulated spade terminals.
    Thanks for the help,
    Keith.
    #141518
    know what you mean with this problem there is a spate of machines using lots of the same colour wires. i have come to the conclusion this is because of the dissability discrimination act as now all engineers whether colour blind or not will be in the same position
    #141519
    Twoten
    Dave_Conway wrote:Sorry, forgot…..
    I still haven’t received the wiring diagram, plesae can you resend,
    thanks,
    Keith.
    #141520
    Dave_Conway
    Twoten wrote:I still haven’t received the wiring diagram, plesae can you resend
    On the way 😀
