Zanussi FLE 1015 W drum problem – request for help
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi FLE 1015 W drum problem – request for help
  • #58132
    frootloops
    The missus has overloaded our washing machine (I keep telling her she does…. I do my fair share of washes before anyone says anything 😆 ) and this time it has broken it.
    My terminology might be wrong, so I’ll try and describe the issue.
    What I think is the inner drum (the shiny silver perforated bit you actually put the wash in) seems to have become disconnected, and is free to wobble about. The end result is that the machine doesn’t spin with any load in. If I turn the pulley at the back with the drum empty it does spin a bit, but it seems loose.
    So I think that either the drum has come off the spider (which seems unlikely as I imagine it’s on with some serious bolts, or some sort of bearing has gone.
    I have disconnected the power and water, and have got the back off the unit, but I’m just after a bit of advice on how best to take the next step and get the whole drum unit out (if needs be) to find out which part is broken and get the replacement part for the repair.
    I’m happy enough messing about with this, so any advice is appreciated.
    Cheers.
    russ
    #333492
    helo_75
    like u say, best thing is to get it apart and look
    take off the motor, all hoses, and the door seal must be unhooked at the front!
    theres white pins at the top of the legs which will pull out if you push in the locking tab
    be wary though , these are heavy drums, so take the weight off from the back
    then you can lift the drum out with the springs at the top
    some people put something under the drum to help support the weight
    take your time and be methodical, make note of all the wiring,,etc and youll be ok
    the tub then splits by undoing all the bolts around the middle
    hope that helps!
    #333493
    frootloops
    Thanks for the super quick reply! 🙂 I’ve taken a look at the seal and can’t quite work out how that comes off. Any tips?
    #333494
    helo_75
    pull the white plastic clip off around the seal, its should then unhook
    #333495
    frootloops
    cool, I’ll take another look. Thanks again.
    #333496
    frootloops
    some help you are, the clip was grey 😉 hehe, and I didnt help myself by looking in the wrong place either.
    next thrilling instalment tomorrow…..
    thanks again.
    #333497
    frootloops
    Re: Zanussi FLE 1015 W drum problem – request for help
    phew….that was a struggle. I couldn’t get the front off (because it seems to be the only thing providing structural rigidity) to get the front weight off, and with no one else around I had a right hassle getting the drum lifted out.
    Got it done though, and the spider has just been completely snapped from it’s shaft!
    So, now on the hunt for the best price for one of those that I have a chance of getting delivered on friday.
    There was also this bit of metal down by the heating element, it seems to have a bit of white paint on it, and I can’t tell if it is snapped from somewhere or not. Any ideas? It kind of looks like part of some sort of circlip
    cheers
    Russ
    #333498
    Seamy
    bottom picture thingy looks like a bra underwire
    #333499
    frootloops
    HA!! 😆 what a spot!
    #333500
    Just to add, the damage to the drum support is as a result of doing low temperature washes, together with liquid or ‘gel’ type detergents.
    Use a decent powder or tablet, do at least one 60° wash every week or do a maintenance wash every month or so to prevent this happening.
    #333501
    frootloops
    thank you for that tip. We do use liquid, and we do a lot of low temp washes so you are spot on! and I don’t think I have ever done a wash at 60, let alone done a maintenance wash! It lasted 10 years though, so now I’m taking your advice maybe I’ll get another 20 🙂
