zanussi fle 1115w no spin after wash
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries zanussi fle 1115w no spin after wash
  • #23182
    delta01
    no spin after wash but apparently spins if spin selected maually
    only approx 2 yrs old says customer . this call is further away than i usually go so i dont want to have to return if pos.
    can anyone advise please
    #197250
    Re: zanussi fle 1115w no spin after wash
    delta01 wrote:can anyone advise please
    Only thought I have is the pump at fault? Slow draining during rinses could cause a spin time-out (usually coupled with an error code?) But I’d stick a new pump in for starters + clean filter etc 😉
    #197251
    delta01
    thanks martin i will run diagnostics and check out the filter etc
    will report back
    #197252
    cab
    check manifold isnt blocked either causing overfilling (hence not draining in timeout) or pressure switch being held on not dropping out to show empty.
    cab
    #197253
    delta01
    went yesterday could not access diagnostics , machine turned out to be six yrs old , customer decided on a replacement thanks for suggestions
