The wash,rinse & spin lights flash together with start light.
This happens when rinse cycle is reached!If prog is restarted on rinse cycle,goes through ok. All other functions work when selected,fills/drains/spins/heats.
Had this fault last year on a similar model.After replacing the heater,pressure switch & motor brushes,fault remained.Pcb became suspect.Am thinking the same?
