Zanussi FLE 1416W Error
  • #7650
    grooster
    I’ve got a Zanussi FLE 1416W, the one without the counterdown screen. The programme starts emptying then when it should click over to fill, but it flashes up the following leds (from top to bottom), 2,3 and 5. I’ve put the machine into diagnostic, havent had much practice at this on one of these machine with no screen and i get a few more flashing light and beeps. The 3rd, 4th and 6th lights light up.
    Has anybody got any ideas.
    Thanks for your help
    Nick
    #124509
    Re: Zanussi FLE 1416W Error
    Grooster,
    Inlet valve open circuit I expect 😉
    Dave_Conway
    If I’m reading the code’s correctly, which I think I am, both of those relate to an ovefill condition, pressure chamber blocked is one and overfill the other.
    Hope that helps.
    #124511
    grooster
    Thanks for the help guys.
    I checked the valves, they are both reading ok and both fill on the test sequence. I tested the main pressure switch and checked for blockages in the chamber, all was ok. I didnt check the smaller pressure switch (overfill), so it could be this.
    Thanks again guys.
    Nick
