Zanussi FLE1015W
  • #19082
    Looked at the lists of error codes but can’t see anything for the push button Zanussis. When you start a wash it locks the door, pump runs for a few seconds then the light above the start/pause button flashes. At the same time the 2nd, 3rd and 5th progress LEDs glow. Do these glowing LEDs form an error code? I checked brushes, tacho, heater and water valve coils, all OK.
    #181656
    Alanj
    Re: Zanussi FLE1015W
    Hi Phil,
    if you take the consul module out you,ll probably find it,s blown, but you can have the diagnostic details if you send me your e-mail address.
    Alan
    #181657
    Thanks Alan, I looked at the main module in the side of the machine and there was no visible damage but do you mean the display module? I will send you a PM. :tup:
    #181658
    Thanks for the diagnostic info. Alan, went back to the machine this afternoon. The initial display test went through all the LEDs in order so I tried the next stage, functional tests. These worked OK up to Phase 7, drain and spin. On this it empties but then an alarm starts and E35 (water level too high) is displayed in binary code. I tried resetting and repeating this with the hose removed from the electronic pressure switch but it still came up with the alarm and E35. At one stage I did get it to start a normal wash and it was working OK until I tried to pause and skip to spin, when it started the usual flashing light business. I suspect the electronic pressure switch might be faulty but I suppose it could still be a problem on the main module 😕
