Zanussi FLE1015W Washing machine-stops after wash
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi FLE1015W Washing machine-stops after wash
  • #71441
    Latham63
    Machine stops at end of wash cycle,having heated water,but not drained! No.2,3,4,5 led`s lit and start led flashing.Start button is now locked and will not now activate until machine is turned off. If, when turned back on,rinse or spin is selected,machine will fill/drain/spin ok! Pcb???
    #381043
    Re: Zanussi FLE1015W Washing machine-stops after wash
    the fault code you state is not listed
    light 2,3 and 4 give you a fault code in the 70’s which tend to be NTC
    but if you let me have your email will send you some light reading which will tell you how to put it in test mode
    Latham63
    Me email is paul_latham@hotmail.com
    With the led`s all lit when stopped it would appear to have aborted and gone back to the start?
    #381045
    sent check your email
